Re: gas shut off
Posted by Bob Kerr on November 06, 2007 at 21:38:32 from (64.12.116.73):
In Reply to: Re: gas shut off posted by Janicholson on November 06, 2007 at 16:42:17:
I fixed the one on my 10-20 just like Jim said. I also repacked the needle with a neoprene "o"ring instead of the rope packing. It works great and just don"t tighten the nut too tight.To get a good seal on the seat, just remember you need a different angle than the needle and it has to be done very straight. The needle will burnish itself into the seat and seal tight if the angles are right.
