As Old says--is gas getting to the engine? When it is running, squirt some oil on the intake manifold/ head joint to see if the engine speed varies. Could be a manifold gasket leak. Second thing to check is the rotor position in relation to spark plug wire contacts inside the distributor cap. Our A with a mag acted a lot like yours, & it turned out that the timing gears on the rotor were off by 2 teeth. If nothing else fixes the problem, might be worth a look.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
