Ben, If your tractor has the 3-position light switch (O-D-B), then the resistor is to Dim the lights in the 'D' position. That's all it does. If you can use a crimp connector to tie the resistor wire's broken ends together, it should work again and won't hurt a thing - maybe the dim lights would be a little brighter due to slightly less resistance. If you don't ever have any need to dim the lights, just jumper the two resistor terminals with a short piece of wire or leave it the way it is.
If you have the L-H-D-B 4-position light switch, it will have two resistors. The one with the large wire is the dimmer resistor. The other resistor is for the low-charge setting for the generator. If it's broken, the Ammeter will not show a charge on the 'L' setting.
Today's Featured Article - Show Coverage: Fair Weather Tractor - by Dave M.. No, Fair Weather isn't some rare brand. It's the kind you can't leave out in the rain. Here's how it happened. I had been casually looking for a tractor for weeks. I saw a few 9N's, but they had even fewer amenities than the 8N my Grandpa bought new in '52 with a Dearborn loader. That was 10 years before I was born, so I grew up thinking that 8N was the world's best tractor. Grandpa had greenhouses, with over half an acre under glass, and that 8N did almost everything. It was the only
... [Read Article]
Latest Ad:
[More Ads]
