Re: 300 vs 350 Operators Manual
Posted by dhermesc on November 08, 2007 at 06:07:50 from (24.248.193.103):
In Reply to: 300 vs 350 Operators Manual posted by agpilot on November 07, 2007 at 14:43:09:
One thing you will find differant - the 350 manual will tell you to use Hytran (or actually its equivelant back in the 1950s) in the transmission and the 300 manual will tell you to use gear lube (80W or there abouts). By the time the 350 rolled out IH had finally learned the TA didn't like heavy oil.
