IH 350 Fast hitch hydraulics
Posted by TomA on November 08, 2007 at 13:42:46 from (4.243.164.80):
I finally got the 350 I bought running and the Fast hitch and power steering do not work. I checked the fluid and it was low and had water in it. I drained it and I plan to pull the cover and check the screen and whatever else is inside. The manual says to use IH Fast Hitch fluid. Can't I use regular hydraulic oil?
