Re: Farmall F-20 width
Posted by Scott Rukke on November 09, 2007 at 20:08:50 from (67.183.230.71):
In Reply to: Re: Farmall F-20 width posted by F-Dean on November 09, 2007 at 19:57:50:
Well I measured 85" outside width with the rims the way they are now. The hub was about 4" deep so I figured I would shave about 8" off. That comes out to 77".
Of course the measurements are all approximately and I won't know till I actually reverse them and try. Do you happen to know the width with them reversed? Looks like you've hauled them before so I assume you're probably right and it won't fit. Gotta try though otherwise it's a flat bed tow charge in addition to the tractor cost. I only paid $350 for the F-20 so I may need to splurge for a tow too. Thanks for the input.
