Re: Water temp gauge check?
Posted by Wayne in MN on November 10, 2007 at 10:09:00 from (68.119.24.60):
In Reply to: Water temp gauge check? posted by Mike CA on November 09, 2007 at 21:16:42:
Water boils ar 212 degrees (or less depending on your altitude) so boil some water, turn off the heat, insert the sensing bulb in the water without touching the container, and the gauge should read close to the boiling point on the gauge face. (If the gauge works!!)
