Re: Here are my valves. Now what?
Posted by FARMALL PULLER on November 11, 2007 at 14:25:45 from (64.12.116.73):
In Reply to: Here are my valves. Now what? posted by Mike CA on November 11, 2007 at 14:00:08:
I guess I got in late on the forum. What is the problem with the valve train? They should oil thier selves when the tractor is running. You can adjust them by turning the engine slow until you get both valves closed on a cylander and get a feeler gauge and loosen the nut on that rocker arm, put your feeler gauge between the top of the valve stem and the bottom of the rocker arm/ Turn the adjuster bolt until the clearance is snug on the feeler gauge, not tight, then tighten the nut on top. Recheck clearance. Move on to the other cylanders that are closed or turn your engine until you get another cylander closed.
