Here are my valves. Now what?
Posted by Mike CA on November 11, 2007 at 14:00:08 from (68.125.174.148):
I got the cover off and managed to save the gasket which is in pretty good shape as far as I can tell. So, below you can see what I'm looking at. As far as I can tell it's pretty clean in there. I took the H out of gear and hooked up the hand crank and started spinning, watching the valves. They all work.
So, now what? Lube them? Check for adjustment? Where do I lube? What do I check?
third party image
