Re: help
Posted by CNKS on November 12, 2007 at 17:43:07 from (216.144.104.128):
In Reply to: help posted by markred on November 12, 2007 at 16:13:02:
If it has a mag, and no lights or generator, you can use a 12 volt for a long time as long as it starts fairly easily. Keep a charger handy. 12 volts will not hurt the starter.
