Re: Electrical/Ignition System C - question
Posted by El Toro on November 13, 2007 at 07:59:13 from (205.188.116.73):
In Reply to: Electrical/Ignition System C - question posted by Harrell Rumfield on November 13, 2007 at 07:47:50:
You need the points closed to have voltage on both small terminals on the coil. The wire from the plus terminal on the coil should go to the distributor if your battery is plus grounded. Take a cotton swab dipped in alcohol and clean those new points. Make sure they're gapped at .020". Hal
PS: Pull the coil wire from cap and hold within 1/4" of good ground and make an attempt to start the tractor with ignition switch on. Should get a hot spark when cranking. You will need a helper.
