Re: ih - farmall 240
Posted by Andy Motteberg on November 13, 2007 at 18:35:30 from (4.143.221.117):
In Reply to: ih - farmall 240 posted by greg p on November 13, 2007 at 14:51:04:
If it has a distributor ignition, you will need to add a resistor. Also remove all your 6 volt light bulbs and put in 12 volt bulbs. Install a 12 volt generator and regulator, or have yours converted to 12 volts. You might be able to find more info on this in the YT Articles, there might be some helpful info there.
