Re: So much for sand blasting on base.
Posted by georgeky on November 13, 2007 at 20:56:02 from (64.12.116.73):
In Reply to: So much for sand blasting on base. posted by Mike CA on November 13, 2007 at 19:05:04:
Mike, do like I did, and set up an electrolisis tank. It is easy with a plastic garbage can, washing soda and a battery charger, which you will need anyhow fooling around with old tractors. It works great. Just take a wire brush and clean the piece up after taking out and it is shiney clean, and ready for paint.
