Re: So much for sand blasting on base.
Posted by El Toro on November 14, 2007 at 04:03:34 from (64.12.116.73):
In Reply to: So much for sand blasting on base. posted by Mike CA on November 13, 2007 at 19:05:04:
They shutdown the steam jenny operation and some of the sandblasting at Aberdeen Proving Ground years ago since they're near the Chesapeake Bay. We bought a Karcher power washer that used K1 kerosene to heat the water after that.Hal
