Re: So much for sand blasting on base.
Posted by Mike CA on November 14, 2007 at 07:12:23 from (214.1.211.251):
In Reply to: So much for sand blasting on base. posted by Nat 2 on November 13, 2007 at 19:05:04:
gene bender said: (quoted from post at 05:20:36 11/14/07) put the pipe in some vinegar for a few days.
Will do. Straight vinegar?
