Posted by Jimmy Bruce on November 14, 2007 at 09:08:51 from (150.199.110.130):
A neighbor has a Super M that he only uses to rake hay with. We split the tractor in half and the clutch fell apart in three pieces. The rivets had sheared off. Everything else looked fine, i.e. throw-out bearing and pressure plate. When I installed the new clutch, same thinkness and style I noticed that when I tightened the pressure plate that the fingers moved from protruding out about an inch to being flush with the pressure plate face. I went ahead and installed the clutch and put the tractor back together. I pressed in the clutch pedal but the transmission would not disengage. I could see the throw-out bearing moving through the grease access hole but it wasn"t quite going up far enough to engage the fingers on the pressure plate. Is this the wrong clutch, it"s the same size and thickness as the one that was in it before, but is that why it tore out the center of the other clutch? I don"t know if the clutch had been changed before and he was just living on borrowed time but I know he has been raking with it for a few years now.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
