Posted by Bill in IL on November 14, 2007 at 09:54:05 from (131.43.10.190):
In Reply to: Super M Clutch Problems posted by Jimmy Bruce on November 14, 2007 at 09:08:51:
I assume you have readjusted the clutch linkage to allow for the new and thicker clutch plate... thicker cause its new and not worn. The thicker plate will cause the fingers of the clutch to be in more and the clutch linkage will have to be adjusted for that.
It would appear not to be the case in your scenario since you can see the throwout bearing not engaging but I have had to start the engine with the clutch depressed/disengaged and transmission in high gear to get the clutch to release from the flywheel/pressure plate even after cleaning both surfaces. Be extremely careful doing this for the obvious reason of being run over or running somthing over.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
