Here's a battery story and a half, but not about a tractor. I bought a silly little French car in 1957, and in 1961, decided to spend the summer with family in California. Left NJ and got all the way to NM when the car just stopped DEAD. I got out and opened the hood and saw a huge smoking hole in the top of the battery. The lead bars were covered with the black goo, but NOT there. I had always tinkered a little with cars, so I got out my tool kit (more like a junk kit--the kind of things all farmers always have around because they "might need that some day"). I put two screws into the lead, one on each side of the hole, wrapped some bare copper wire around them, and turned on the lights. GOOD BATTERY still! Then I had my wife turn the key and heard the solenoid click in, but the starter motor did not run. Right there in the middle of the most barren desert I had ever seen up to that point, I took the solenoid off and removed the end cap. The big copper contact that pulls in to operate the starter had dropped off and shorted out the battery. I figured that since I had a solenoid and a battery, I could just take out the contact, have my wife operate the solenoid, and I'd short out the motor contacts with a big screwdriver. The motor took off like a rocket, and we drove 600 miles that day and night, stopping the engine only once for gas and a meal. In LA, I was able to get a new solenoid/switch and away we went again. Later, I wondered if I could have fixed that switch in the desert. I now think that the contact was riveted to the solenoid stem, and that the constant pulling over several years had loosened the peened-over stem. Truth to tell, I was too flustered to think of this solution and was only too happy to make the little devil run. I am not given to much shouting or jumping around, but I did a dance when that thing started. I even told myself I was a mechanical genius, which is, of course, just a slight exaggeration. I have never heard of this happening, and it has never happened to me on any other car. French cars back then were not exactly considered the greatest pieces of machinery, but I was young and naive, and read in a sports-car magazine that this car was a delight to handle. Well, at least you could reach the parts when they went out. Oh, there was one other little problem. I had put a big rack on the roof to handle our luggage, and the extra load made the engine run hot enough to burn an exhaust valve. Well, you could reach the parts when they went out, so I pulled the head and had somebody grind the valves. When I got back to NJ, guess what? Another burned exhaust valve. But then the parts were easy enough to get out when they went out....... Didn't keep that one much longer.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
