Re: 1947 BN / alternator carb question
Posted by Bob on November 16, 2007 at 01:41:36 from (69.178.229.154):
In Reply to: 1947 BN / alternator carb question posted by Josh in Maine on November 16, 2007 at 00:15:46:
1.) A "12 Volt" battery is VERY comfortable being charged at 14.4 Volts.
2.) An alternator of any common size SHOULD keep up with 2 or 3 lamps without the charging voltage dropping much.
3.) To solve the "doesn't idle down" problem, the linkage rod between the governor arm and the throttle lever on the carburetor needs to be adjusted for LENGTH according to the procedure in the service manual. If that doesn't solve the problem, an OH of the governor is indicated. You DO NOT need a "return spring" on the carburetor's throttle lever.
