Re: 1947 BN / alternator carb question
Posted by Brownie450 on November 16, 2007 at 03:44:00 from (207.177.82.156):
In Reply to: 1947 BN / alternator carb question posted by Josh in Maine on November 16, 2007 at 00:15:46:
The governor problem could be caused by a needle roller bearing in the "long arm" of the governor. With age, these bearings tended to get a small amount of moisture from crankcase vapors [blow-by, cold weather] & tended to rust & "drag" on the governor shaft which controls the throttle plate. These parts are still available from IH. If the throttle rod adjustment doesn't correct the problem, have a go at the governor. As far as the alternator voltage dropping with lights on, as long as it doesn't drop below 13.6 to 13.8, I wouldn't worry. If it's much less, You probably have 1/3 or 2/3 of the diode trio open. Easy to replace.
