Josh, The alternators main output stud/terminal indeed wires to the LOAD (NOT Battery/Starter) side of an ammeter while its other SUPPLY terminal is fed voltage from the hot ungrounded battery post often via a wire to the starter switch where the big battery cables attaches...
Next, loads like lights and ignition (if its a coil ignition instead of a mag) should also be fed from the ammeters LOAD terminal which is the same terminal where the alternators output is connected.
As far as voltage, that 14 and over range is typical of what many alternators will raise battery voltage to, so unless the battery boils over and/or outgasses badly Id not worry for now.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
