Re: 1947 BN / alternator carb question
Posted by ScottyHOMEy on November 16, 2007 at 09:19:15 from (71.241.213.254):
In Reply to: 1947 BN / alternator carb question posted by Josh in Maine on November 16, 2007 at 00:15:46:
HAve you got the rod on the left side from the governor to the carb adjusted? Engine off. Throttle control all the wya forward. Pull the clevis pin at the front of that rod. Holding the rod all the way back and holding the governor arma s far toward the rear as it will go, adjust that clevis on the thread until it lines up and replace the pin.
It maya lso be one of the needle bearings someone mentioned down below.
I' check these things out before going into the governor.
Whereabouts on the coast? I'm just past Belfast.
