Re: So much for sand blasting on base.
Posted by Mike CA on November 16, 2007 at 20:21:29 from (64.173.170.16):
In Reply to: So much for sand blasting on base. posted by Mike CA on November 13, 2007 at 19:05:04:
F-Dean said: Yes, sand is a hazardous material according to the EPA. That is why we now use "Grit" for sand blasting.
Mike, try to get the environmental office to approve blasting with an environmentally approved blasting agent. After all, we would not like to have you California guys exposed to sand. Especially, Navy guys in California!
Sometimes I wonder what this world is coming to!!!
Actually, it makes sense. The sand is knocking loose hazardous materials like paint, oil, hydraulic fluid, etc. If that goes down a regular drain it will contaminate. I just wish they would secure the area better, rather than just shutting the whole thing down.
