Posted by Janicholson on November 16, 2007 at 20:47:34 from (66.173.50.169):
In Reply to: Bolt torque for H? posted by Mike CA on November 16, 2007 at 20:27:07:
Flatten the edges on a block of wood so each bolt hole is flat. Put #2 nonhardening permatex (just a film, no more)on the sheet metal side on both components. Be sure to put the long bolts in the front and rear of the pan where they came from. Tighten bolts until they are just tight enough to make everything contact without force. then tighten a little each until the gasket is seen to be squishing from tightness (a little bulge at the bolt) that is it. It is always better to be able to tighten them than it is to reflatten and replace a split gasket. JimN
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
