Re: 1926McCormick-Deering 10-20
Posted by Bob Kerr on November 16, 2007 at 21:13:30 from (205.188.116.73):
In Reply to: 1926McCormick-Deering 10-20 posted by ViperDave on November 16, 2007 at 07:09:49:
Instead of pulling the engine I would just take the pistons out and clean them up and if the sleeves are surface rusted just give them a very quick clean up hone. If it wasn"t started after rebuild I would look at the cam also to clean surface rust off it. I would change the oil right after getting it going like about 10 min or so, in case there is any crud that gets cleaned up from moving again. The one I rebuilt was in simillar but worse shape than yours. I think the barn it was parked in fell on it as the steering post was cracked and pushed down and the steering wheel broke up and it sat outside for 30 some years with the hood off. I Had mine rebuilt from the clutch forward and plowing in a month and a half! You will shurly enjoy the day when the old gal runs and first moves under its own power again!
