Posted by FromJB2 on November 17, 2007 at 17:24:40 from (156.34.150.171):
In Reply to: Lack of power posted by RBPrice on November 17, 2007 at 16:28:52:
Bob, some additional checks: 1) Disconnect fuel line where it feeds into the top of the fuel filter and catch fuel in a clean container. The fuel should flow at the full of the fuel line. If it doesn’t, there is probably junk in the outlet in the bottom of the fuel tank. Can blow compressed air backup the fuel line as a temporary fix but the problem will come back. My brother had a lady bug carcass in his 684 fuel tank causing similar problems. 2) Check the adjustment on the STOP/START/RUN control cable. With the STOP/START/RUN lever all the way up the control arm on the fuel injection pump that is attached to the control cable should be all the way forward touching the adjustment stop screw
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
