Re: steering play on narrow M
Posted by glennster on November 17, 2007 at 20:18:49 from (68.60.242.156):
In Reply to: Re: steering play on narrow M posted by little john on November 17, 2007 at 11:09:20:
if you have a puller hooked up on the top gear, get some tension on it and then strike the center bolt on the puller with a 3 lb hammer. 2 or three whacks and it should drop off. i have the front end up a couple inches off the ground with the wheels still on. gives it a little extra weight and, that bolster shaft is pretty heavy. if the front end is off and that sucker drops on yer foot, it 'll wake ya right up!!!
