Re: IH 424 Rear Differential Lock - How do I use it?
Posted by Hugh MacKay on November 18, 2007 at 06:40:22 from (209.226.247.52):
In Reply to: IH 424 Rear Differential Lock - How do I use it? posted by chibbert on November 18, 2007 at 04:57:01:
Chris: You should never engage the diff lock with a wheel or wheels spinning or during a turn. Oh, it will work for awhile, but you vastly shorten it's life.
That diff lock only stays engaged while you have your foot on the pedal. If you want to test it, see if it works, step on the pedal, hold it down while moving on gravel roadway, and try turning. If it's working you should notice front wheels slipping and rear wheel slipping on the side in the direction your turning.
