Posted by Trent544 on November 18, 2007 at 17:50:55 from (166.82.246.61):
I was just reading below about V8's not having as good of fuel economy as the turbo 6 cylinders. I owned a 1468 for a short time and worked it in the field some. I was so surprised by how little fuel it used I went to my Nebraska Test book and found out this:
On the ten hour drawbar test (75% of drawbar horsepower) which I think is the best test to compare tractors in real field conditons the results are as follows:
test 1125 on the 1466=100.58 hp and 12.01 hp hrs/gallon test 1118 on the 1468=107.23 hp and 13.22 hp hrs/gallon
test 1174 on the 1566=110.79 hp and 11.69 hp hrs/gallon test 1175 on the 1568=108.44 hp and 12.59 hp hrs/gallon
Otherwise the six cylinders had better economy at 1000 rpm on the pto. They reached 1000 pto rpm's at about 2270 engine rpm. The six cylinders seemed to lose a LOT of economy going up to the rated 2600 rpm from pto speed of 2270.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
