Farmall A Non-Electric?
Posted by Tims-A on November 19, 2007 at 16:46:12 from (172.166.189.126):
Did any of the early A's come from the factory non-electric?(crank start only)
If they did, what was the arrangement for a shut-off switch. Mine has a mechanical push button/cable mounted on the steering support. It may have grounded the magneto at one time. Would this have been stock?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
