The very early Farmall A shad no provision for electric starting, crank start only. There are photographs showing a push-down tab on the magneto for stopping the engine, later replaced by a Bowden cable operated cut-out. Also, some early Farmall A tractors appear to have had a lever poking out of the bottom left-hand side of the radiator sheild to operate the shutters rather than the later crank on the rear tank support. (these may have been prototype tractors as some had disk front wheels and two spoke steering wheels)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
