farmall M
Posted by Pat-CT on November 20, 2007 at 12:57:51 from (68.110.205.165):
for my senior year FFA project that will start after winter sometime do you think an M would be a good choice i already have an H and am complteing it this winter but next year i want soemthing bigger stronger my reasons are becuase i have permission to run the bailer at the FFA voag fair next year if i have a tractor that can handle it and i drive it to all the shows local as i do with my h and i would like something that can handle the hills a little bit better then my H i also do stock pulling when one comes close enoguh (only 2 a year)
my choices for this is a farmall M460 if i can find one cheap enough,olive 88,john deere A, or allis chalmers wd45 as those are in the HP class i want but ive liked my famrall H for the last year and a half so im doing research now thanbks and have a good evning -PAT
