Re: farmall M
Posted by City-Boy McCoy on November 20, 2007 at 14:41:49 from (209.214.105.95):
In Reply to: farmall M posted by Pat-CT on November 20, 2007 at 12:57:51:
Pat: You can't go wrong with an M. They are cheap, plentiful, used parts are readily available. Additionally, the M is an easy tractor to boost horsepower if you want to go that route later. Also, there were add-ons such as power steering, etc. which will make your M more comfortable and unique to your preferences. Hard to beat an M for the money. mike durhan
