OK Terry, are you saying that you FOUND something that looks like a washer spacer in one of the final drive pans or do you mean one of the washers that go on the axle shaft end behind the bearing caps?????
What I'm getting is that you found a concave part in the pan.....
If so then take a close look at this piece. If the edges are rough and upon closer inspection look broken then I can tell you that it is part of the casting of the final drive, the backside of one of the threaded implement holes, that has broken off due to over tightening of the attaching bolts.
As for the rivets, you will need a helper to backup the rivet while you peen it. Just use a heavy bar or something and have him back up the rivet while you snug it up on the other with a flat punch and hammer. If it's really loose you could use a centerpunch too.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
