Hugh MacKay and other Farmall A gurus
Posted by tn terry t on November 20, 2007 at 19:36:40 from (64.12.116.73):
please help me figure my axle bullgear problem siting on the tractor the left side. when i pulled the pan off to replace the gasket i noticed that the rivits that hold the bullgear together had been rubing the inside if the case just below the pinion gear i pulled up the parts break-down and every thing is in there thats supposed to be. only thing im not sure about there is a "concaved"washer-spacer in there which way should the washer be in there? also the rivits are loose can i just peen them tight or is there somthing special i need to do? any ideas other than a reversed washer?
