Re: Gene Bender - Vinegar in radiator question
Posted by old on November 21, 2007 at 08:21:20 from (4.244.57.38):
In Reply to: Gene Bender - Vinegar in radiator question posted by Mike CA on November 21, 2007 at 07:54:05:
Well I'm not Gene but, I have used the vinagar flush often and it does work well. 100% vinagar, run the engine till good and warm/hot. Let cool for safety and then drain flush with water. I made a rig that screws into the block drain and hook up a garden hose to it and back flush it for an hour or so. I have an Oliver 77 that would over heat on and and after I did that about 5 years ago it hasn't once over heated on me.
