Re: Gene Bender - Vinegar in radiator question
Posted by Mike CA on November 21, 2007 at 08:41:40 from (214.1.211.251):
In Reply to: Gene Bender - Vinegar in radiator question posted by Hugh MacKay on November 21, 2007 at 07:54:05:
Mike Farmer said: (quoted from post at 09:39:53 11/21/07) Over the years I've tried all kinds of things but I always come back to the same cure. Washing Soda. 3Lbs of soda to 6 US gallons of water.Leave the radiator cap off and operate tractor till the water gets hot, work for a while at high temp then drain and refill with whatever solution you would normally use. If its really bad try Caustic Soda MTF
My tractor won't be able to work. Best I could do is just drive it around a little while. I doubt that will get it hot from what I read.
