Re: Gene Bender - Vinegar in radiator question
Posted by Bob M on November 21, 2007 at 09:51:34 from (151.190.254.108):
In Reply to: Gene Bender - Vinegar in radiator question posted by Mike CA on November 21, 2007 at 07:54:05:
In years past one of the antifreeze manufacturers (Xerex perhaps?) sold a "2 part radiator flush" that worked very well to remove scale, etc.
First part was an acid powder (oxalic acid I think...) You'd dump the acid into a system filled with straight water, then run the engine for an hour or two for it to circulate and work.
You'd then drain/flush a couple times with fresh water, then dump in the "neutralizer" powder(probably bicarbonate of soda) and let that circulate a few minutes.
Finally you'd drain/flush the system a couple more times with fresh water.
Worked best if you removed the thermostat and partially blocked the radiator to get good (and hot) water flow thru the radiator.
Don't know whether 2 part flush is still around...
