F-20 engine rebuild
Posted by Scott Rukke on November 21, 2007 at 18:12:18 from (67.183.230.71):
I have a few questions as I wait for my service manual to arrive. I have my F-20 engine out and removed the pistons today. Why all the shims between the rods and caps?
This is an untouched engine and I need to know the rod bearing to crank journal clearance. The bearings are good and the journals are good and I was going to use plastigage to measure the clearance. What is the rod bolt torque? Also does anyone know the ring gap locations? Or is it important. I always space them according to the manuals for my car engines. Thanks in advance.
