Re: F-20 engine rebuild
Posted by Nebraska Cowman on November 22, 2007 at 03:41:48 from (65.162.146.41):
In Reply to: F-20 engine rebuild posted by Scott Rukke on November 21, 2007 at 18:12:18:
The shims are to take up wear but you probably figured that out. You want them as snug as you can get them without binding. Turn the enging a full revelution when checking as the cranks tend to wear out of round. I tighten everything by "feel" so can't help with specs. Just stagger the ring gaps.
