Re: Super A carburetor identification
Posted by MIKE FRENCH on November 22, 2007 at 11:23:23 from (71.50.16.182):
In Reply to: Super A carburetor identification posted by Bill Gross on November 22, 2007 at 10:16:12:
There should be a tag with the number on the carb, it might of had a tag that was held on by one of the screws that holds the carb together and was not put back on, best is to place a picture or try to match it up with the correct kit. Lots of As, Bs, And Cs have had replacement carb put on throught the years. A local carquest store should be ababile to match a kit up to your carb. Hope this helps.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
