Re: Steering shaft won't quite connect
Posted by Dave S. on November 22, 2007 at 16:44:41 from (204.96.146.26):
In Reply to: Steering shaft won't quite connect posted by Mike CA on November 22, 2007 at 16:27:15:
Make sure the steering shaft is in position where it is suppose to be and the plug on the steering box is tight. Go to the steeting post by the steering wheel and loosen the setscrews on the two collars where the shaft goes through the steering post. Now you can slide the shaft back or forward to where you need it and then retighten the setscrews on the collars
Dave
