Re: Hydraulic Turmoil
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by ltf in nc on February 22, 2000 at 19:34:47 from (206.228.213.75):
In Reply to: Hydraulic Turmoil posted by DrCyKosis on February 22, 2000 at 17:42:45:
I have two of these tractors, I like both of them. The oil cooler is mounted on the grill side of the radiator and is easily cleaned by removing the grill. It will be caked with dirt and oil. Obviously you with need to pivot it away from the radiator and clean it. Brake cleaner works good. Most likey this will not extinguish the lamp when the oil is hot. If the pto works without slipping (pressure controlled), I would not fret over the light as it is probably a "switch" thing. You are using Hy-Tran fluid aren't you?
Post A Followup
: Re: Re: Hydraulic Turmoil
