Re: H Needs new gear
Posted by Bob Kerr on November 23, 2007 at 16:14:34 from (205.188.116.73):
In Reply to: H Needs new gear posted by JJ in MI on November 23, 2007 at 13:48:43:
While you are in there check those bearings out. That is the time to do replacing if need be. Also better change the lower gear. Get them in the set that they ran with otherwise you will get noise. Get bearings and seals at a bearing house and it will save you a TON of $$$. I got my gaskets from CaseIH.
