Re: Steering shaft won't quite connect
Posted by Mike CA on November 23, 2007 at 17:18:32 from (76.239.186.148):
In Reply to: Steering shaft won't quite connect posted by Mike CA on November 22, 2007 at 16:27:15:
Andy Martin said: Check the steering column. If you have the worm gear bearing seated well, the steering column may be loose or bent. This is the structure that holds the steering wheel. It should have two set screw rings around the steering shaft to hold it in place.
Also, if you have the tractor jacked up and have loosened the frame rails, you may be out of alignment there, that is, if the frame rails are loose and hanging down toward the front, the steering shaft will be too short. Same thing if the bolster has been loosened.
Did you make sure the seat for the worm gear bearing was clean?
The steering column hasn't changed since I took the steering shaft apart. And I haven't done anything to the frame. But I will double check the inside cleanliness.
