Re: 6 volt system, has a 12 volt coil
Posted by Hugh MacKay on November 24, 2007 at 02:30:13 from (216.208.58.116):
In Reply to: 6 volt system, has a 12 volt coil posted by MikeK on November 23, 2007 at 20:15:32:
Mike: Most situations we encounter on here are folks switching to 12 volt and putting a resistor in the system to reduce the voltage going to a 6 volt coil. Think about this, you already have reduced voltage going to a 12 volt coil. If you add a resistor you'll only reduce the voltage further. My thoughts if you have a true 12 volt coil your voltage at the points is already too low, the resistor will only reduce voltage even further. Your solution is go to a 6 volt coil.
Another factor you must consider is for some weird reason some 12 volt coils are labled 12 volt coil no external resistor required, while others are labled 12 volt coil requiring a added resistor. As I see it the first one is a true 12 volt coil, while the second example is nothing more than a 6 volt coil requiring a resistor when used as 12 volt. Why industry doesn't just call them 12 and 6 volt coils, beats me.
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
