Mike, a 12 volt coil will produce a spark if only supplied with 6 volts but it will be weak and no, I dont see that as the cause of your condensor problems. Ive seen coils labeled:
"12 Volts NOT for use with external ballast resistor" which are indeed full true 12 volt coils
"12 volts for use with (or requires) external ballast resistor" They are indeed actually 6 volt coils and such will work fine on a 6 volt tractor. They are used on 12 volt tractors that use a 6 volt coil and most have the start by pass feature which allows for a hotter start up spark, They sort of start on 12 volts and run on 6 volts.
Theres a common misperception (old wives tale) out there that all coils are 6 volt coils simply NOT true. A full true 12 volt coil has a primary winding resistance (measured between its lil + and - terminals) of around 2.5 to 3.5 ohms or so while a 6 volt coils is more like 1.25 to 2 ohms. ALSO some people refer to 12 volt coils as "internally ballasted" which some think have a built in discrete ballast resistor wired in series before the coil winding HOWEVER most achieve the added primary winding resistance simply either by having more primary wire/winding length or else use wire having a higher resistance per unit of measurement.
One limiting factor and the reason 6 and 12 volt coils are indeed different concerns the life of the ignition contact points which is limiting the current they are required to switch unde load to around 3 to 4 amps or so..... Thats why a 6 volt coil has say 1.5 ohms or primary resistance 6/1.5 = 4 amps) and a 12 volt coil say 3 ohms (12/3 = 4 amps)...... AND THEY ARE NOT ALL THE SAME 6 VOLT COIL........
BOTTOM LINE you need a 6 volt coil on a 6 volt tractor cuz a 12 volt coil will produce a weak spark. All coils are NOT 6 volt coils, see the explanation and reasons why above
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and
... [Read Article]
Latest Ad:
[More Ads]
