Re: 6 volt system, has a 12 volt coil
Posted by Michael Koch on November 24, 2007 at 20:36:52 from (12.208.208.221):
In Reply to: Re: 6 volt system, has a 12 volt coil posted by John T on November 24, 2007 at 06:11:43:
Hello,
Thanks for all the help! I checked the coil and it is running avout 1.7-1.9 ohms. So it must be a 6 volt coil, with 12v on the side.
Again thanks for the help. I hope to try this out this week.
Today's Featured Article - Tuning Up Your Tractor: Cooling and Fuel Systems, Hoses and Belts - by Curtis Von Fange. Our tractor is coming right along. The old oil and filter has been taken to the recycler and the air filter replacement has breathed new life into our motor. Let's take a closer look, now, at the cooling system since it has to work so hard in the summer heat. Cooling systems can be real cantankerous in their old age. Radiator cores clog up with rust, lime or other mineral deposits and the fins clog up with weed seeds and debris. The metal headers slowly corrode away from years of use and ... [Read Article]
