Re: IH 300 utility Hyd. pressure problem
Posted by Janicholson on November 24, 2007 at 06:28:42 from (66.173.50.153):
In Reply to: IH 300 utility Hyd. pressure problem posted by Dan Cook on November 24, 2007 at 06:08:16:
Most likely a worn pump. Though not the good news, they are available. Having it tested for pressure is probably worth the effort. If the pump is good there could be an issue with the pressure regulator system under the seat. A manual, and the parts diagram caseih.com are very useful. JimN
