Re: IH 300 utility Hyd. pressure problem
Posted by edward_m on November 24, 2007 at 08:35:48 from (67.55.240.130):
In Reply to: Re: IH 300 utility Hyd. pressure problem posted by Janicholson on November 24, 2007 at 06:28:42:
Might also want to check the pressure relief valve. Had a 400 that was weak, or at least seemed to be, with a loader. Found out that the spring in the valve had broken, so the valve effectively released under a lot less pressure than it normally would.
It could still be a bad pump, but I'd check the easy (cheap) stuff first.
